Tractor Talk Discussion Forum
weight of a standard square bale?
ssgshelton
05-24-2008 20:10:13
I have baled close to 150 square bales this weekend with my NH 273 baler. The first 100 were heavy as heck, the next 50 I baled a little loose and they seemed a little too light. I am going to weigh the two types of bales tomorrow and have probably another 100 to bale. My question is, how much should a standard square bale weigh? I am about going to come close to running out of room to store them so I want to go a little heavier without breaking my back stacking them. I am a one man operation.
thanks
E.B. Haymakin'
05-25-2008 15:13:51
 Re: weight of a standard square bale? in reply to ssgshelton, 05-24-2008 20:10:13
Your windrows are just a important as the tension on the bale chamber. I finally realized late last year that my 273 likes good sized windrows to make decent heavy bales.
Sam#3
05-25-2008 05:52:42
I know the world has changed a lot in the last fifty years but when I was bucking bales in the 50s & 60s the target was sixty-five pounds. However, if sold by the ton and un-weighed the custom was 'thirty-three bales to the ton.' Sixty-five seemed a good weight to handle. You weren't likely to bust a gut and in a pinch (long walk to the truck) you could carry one in each hand.
Amazing what a country kid would do for a penny a bale or $.75 an hour whichever they paid that year.
kyhayman
05-24-2008 21:01:54
That depends on local custom. Around here, people talk about a 50 pound bale, and it seems most people run 38 inches in length. When I increased my bale tension, I had to go to a shorter bale. Its a 'buy by the bale' market here.
old
05-24-2008 20:32:47
Around 75lbs is pretty much standard give or take a few pounds. Me I bale them at around 40lbs which is still 5lbs more then the doctors say I should lift. I use a NH271 and ya I can pack them in tighter but why do so you only have one back and when it goes your screwed big time I know because mine is
Sam from WA
05-24-2008 20:25:36
We try to keep ours in the 65 to 70 pound range. Makes them easier to handle. I'm using a New Holland 426 with hydraulic tension.
garytomaszewski
05-24-2008 20:22:04
Walts numbers are right 50-80 but the little horsey girls here want 40 so they can lift them. Same price to me so I'll bale two 40s instead of one 80.
jose bagge
05-24-2008 20:32:12
 Re: weight of a standard square bale? in reply to garytomaszewski, 05-24-2008 20:22:04
my little horsey girls would bust your a$$ if you tried to sell them a 40lb bale! This is a good question, though- is a 75lb bale sold for 7.50 a better deal than a 50 lb bale for 6.00? You'd think so, but weight rarely seems to be an issue in hay discussions out here....
Walt davies
05-24-2008 20:13:16
50 to 80 is what I bale them at.
Walt
