Tractor Talk Discussion Forum
OT AM radio in a Freightliner Columbia (2002)
Eugene SWIA
05-25-2008 06:26:40
AM side of radio don't have reception worth a darn. Was told at FTLINER there is a box that combines FM AM and weather band and will fail. Wouldn't mind replacing radio but then maybe be the box thats bad. Some guys I talk to say none of the later models have good AM reception.So if I replace both will I have decent AM or not
Thanks. Gene
504-2
05-25-2008 20:32:28
 Re: OT AM radio in a Freightliner Columbia (2002) in reply to Eugene SWIA, 05-25-2008 06:26:40
Eugene, I had the same problem with a 2005 Business Class the antenna had come unplugged at the radio. It was like that from day one, I took out the cubby hole next to it and plugged back in.(mounted overhead)
SDLoy
05-25-2008 09:05:22
Most of the newer Freightliners duplex the CB and AM/FM radios thru what you think is just the CB antennas. If the CB antennas have been replaced, that may be your problem as these trucks require special antennas to do both jobs. The antennas are available at your Freightliner dealer and really aren't any more money than truck stop antennas. Loy
rednekelmo
05-25-2008 08:26:42
I just gave up an got an xm sky-fi.I had some luck with a better antenna from C-crane. check all of your antena connections , if you have a spare radio try it out for fun
RustyFarmall
05-25-2008 07:32:27
AM radio just isn't what it used to be. I get very annoyed at the static and interferance associated with AM, so I mostly just tune in on the FM side. Don't know anything about the radio in your Freightliner, but I would imagine you could just pull it out and replace with a good aftermarket unit and be done.
