154 Cub Loboy clutch problem
Rich Flanagan
04-08-2000 16:09:35
I just got a 154 Cub Loboy. When I put it into reverse the clutch grinds. It's fine when I put it into the other gears though. Is this a sign my clutch is going, or is there some kind of adjustment I can make to fix it? Thanks.
Jason
06-27-2004 20:54:20
 Re: 154 Cub Loboy clutch problem in reply to Rich Flanagan, 04-08-2000 16:09:35
Well me and my dad own a 1972 International Cub 154 Lo-Boy.It seems that when ever you don't put the clutch in all the way in and i meen all the way in it will to do that.Because the drive shaft is still spinin'
Kent
04-09-2000 07:19:14
Rich,
Take the cover off between the seat and the steering column. Push the clutch pedal down and check to see if the input shaft to the transmission stops spinning. If not you need to checkout the braking function of the clutch mechanism. As the clutch fully releases, there are two small round brake pads which are suppost to stop the input shaft.
Good Luck,
Kent
