Farmall A timing adjustment
Posted by John Martin on September 23, 2002 at 12:30:10 from (209.184.210.1):
This past weekend I finally got around to trying the static timing adjustment some of you advised me on. Got the #1 cylinder at top of compression stroke, perfectly lined up the timing mark on the flywheel with the one on the clutch housing dust cover, and made sure the rotor was pointing at #1 post on the distributor cap. Removed cap, rotor, and cover over the points so I could watch them as I moved the distributor (for reference, my distributor has been converted from the original magneto to a 12-volt system, with points and a condenser, and an external 12-volt coil). Previous posts suggested moving the distributor fully retarded and then advance until the points JUST start to open. I tried that...and...the rubbing block on the points never comes close to either cam. In other words, the points don't open any amount with full travel through the range of adjustment of the distributor. This explains (at least to me it does) why I couldn't set the timing with the timing light...something is messed up that has the timimg retarded significanly. My guess is that it is off by 30-40 degrees, which is the figure I had posted before. I have no explanation for this problem. I imagine excessive engine wear could cause the timing to be off by this much. Any other ideas? Timing gear jumped a tooth? Engine maintenance done in the past (before I got the tractor) and not put back correctly? I think I can compensate for the problem by changing rotor position relative to distributor rotation by moving the rotor gear (the driven gear under the cover under the rotor) in the direction that would advance the timing. I would move it a tooth at a time and then check the timing (with a timing light) to see how far I advanced it. By doing so, with all else staying the same, the rotor reaches each position on the cap earlier, or more advanced by the number of degrees of rotation each gear represents. The static method won't work for my anyway, so I have to try something. If this doesn't work, I have to go into the distributor or the engine, which would be much more complex than the 5-minute fix of moving the gear. Anyone ever try this before? Won't get a chance to do anything until next Saturday at the earliest, so keep the ideas coming, and as always any help is appreciated.
Home
| Forums
Today's Featured Article -
A City Guy's First Tractor - by Fred Hambrecht. After living in apartments in Atlanta for more years than I care to remember, the wife and I decided to move to the country. Humming "Green Acres is the place for me..." we purchased a 29 acre tract about 60 miles south of Atlanta. Next came the house, I could talk about that ordeal for another two weeks... But, I want to talk about my tractor! We didn't even own a lawnmower, and all of a sudden we had enough grass to feed all the starving children of the bovine world. Naturally, I talked
... [Read Article]
Latest Ad:
Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor
[More Ads]
Copyright © 1997-2024 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
