Re: Farmall A timing adjustment
Posted by ScottyNY Longish on September 23, 2002 at 15:09:54 from (151.202.182.234):
In Reply to: Farmall A timing adjustment posted by John Martin on September 23, 2002 at 12:30:10:
John: There've been enough timing questions lately that I'm not sure which were yours, so forgive me if I hit something that's already been suggested. Also have no idea of your experience, so aplogies If I say something too basic. No insults intended. First off, if the high spot on the cam is passing under the rub block on the spring side of the points without opening them, then the points are adjusted way too tight. You set the points to the right gap while the high spot of the cam is under the block. IF it's a matter of the cam lobe never getting under the block across the span you can turn the distributor, then it's entirely possible that your cam or governor drive gear is out of time. The fully correct way to check this is to remove the front end, pull the crank pulley and timing cover and line up the marks on the cam, crank and governor gears. What you might want to try first -- *only* if you're confident that your valves are in the right position at TDC (that means the cam is properly timed to the crank)-- is pull the front off the governor, then pull the gear forward out of the bushing and re-orient it so that it puts your distributor in a position that the dist cam lobes can reach the rub block on the points (You won't be able to see the punch mark on the cam gear with the timing cover on, so, with everything else at TDC try starting with meshing the spot with two punch marks between teeth of the governor gear with the cam gear). This isn't just according to Hoyle, but it should put you in the range where you can make the adjustment if the problem is with the timing of the governor gear. Engine wear wouldn't throw it out this far, and it would have had to jump more than one tooth. If the cam gear is on tight, it sounds more like someone worked on the governor, took the gear out and didn't get it back in right. Sorry for the length. Good luck! ScottyNY
Home
| Forums
Today's Featured Article -
Tractor Proflie: John Deere Model R - by Staff. The John Deere Model R, the last of the lettered tractors, was the first diesel-powered tractor produced by John Deere with a gasoline starting engine. It was also the first tractor they produced that had an optional steel cab. The photo above shows the tractor w
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2024 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
