Re: Farmall 100 Engine Rebuild Questions
Posted by ZANE on November 10, 2004 at 05:29:04 from (64.12.117.13):
In Reply to: Farmall 100 Engine Rebuild Questions posted by Hobo,NC on November 09, 2004 at 18:14:37:
Hobo the sleeves are wet type sleeves with rubber O ring seals at the bottom of the sleeve where they meet the block and the head gasket seals them at top if my memory serves me right. I worked at an IH dealership from about 1967 through 1970 or so. Getting the sleeves out is like taking candy from a baby compared to the N engine with the dry sleeve. I seem to remember that the bottom of the sleeve protrudes into the crankcase by at least an inch or so and you can use a block of hard wood or brass drift to knock the sleeve up till it is free. Be sure to clean the block where the O rings go and at the top where the lip of the sleeve sits so you don't have any leaks when you go back. Grease the new sleeve seals good and the new sleeves will just slip in easy by hand. Most of the old IH engines like the one in your 100 came with low compression because most of the older tractors were designed to burn distillate or kerosene etc. and that requires low compression ratio. There were what they called the "super" kits available to use if you planned on using strictly gasoline fuel. This is the reason for the Domed pistons. Usually the sleeve was a little thinner too with increased cubic inch for more compression. I forget the claims for power increase but it did seem to have some effect on power increase. I wouldn't worry myself about the end play on the crankshaft. This ain't a rocket engine! :O) I think I would go with the standard crank if it is within tolerances. Not over /002 wear and fairly round. I have never seen a broken crank in an IH tractor. The front pulley on some of these engines is a chore to get off. Press fit and that's it! Really need a good gear puller that you can clamp around the back of the pulley to pull it off. That engine was the same basically as the C, H, A and B IH tractors. Probably some others too. Zane
Home
| Forums
Today's Featured Article -
A City Guy's First Tractor - by Fred Hambrecht. After living in apartments in Atlanta for more years than I care to remember, the wife and I decided to move to the country. Humming "Green Acres is the place for me..." we purchased a 29 acre tract about 60 miles south of Atlanta. Next came the house, I could talk about that ordeal for another two weeks... But, I want to talk about my tractor! We didn't even own a lawnmower, and all of a sudden we had enough grass to feed all the starving children of the bovine world. Naturally, I talked
... [Read Article]
Latest Ad:
Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor
[More Ads]
Copyright © 1997-2024 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
