Re: M Charging Woes
Posted by Bob M on May 13, 2005 at 09:37:33 from (151.190.254.108):
In Reply to: M Charging Woes posted by Matthew(Mich) on May 13, 2005 at 09:14:01:
Matthew - A couple of thoughts:
1 – If you’ve truly got a voltage regulator and not a cutout installed (a regulator has 4 terminals labeled GEN, BAT, FLD and L), the light switch will have no effect on charging rate. (The L and H light switch positions are both now simply “off” positions for the lights)
2 – 5 amps of charge only at mid-idle is puzzling. It should be closer to 10 – 15 amps from mid-idle to full RPM. A couple of possibilities for this:
It’s wired up wrong. Here’s a link for a diagram how a regulator should be wired up:
http://albums.photo.epson.com/j/ViewPhoto?u=4001561&a=30065733&p=60243464
If you find it’s wired up OK, then try working your way through the troubleshooting chart here:
http://albums.photo.epson.com/j/ViewPhoto?u=4001561&a=30065733&p=63426275
It will not correct the problem, but it will help you identify which component is causing the problem.
Good luck!!
Post a Followup
Today's Featured Article - A City Guy's First Tractor - by Fred Hambrecht. After living in apartments in Atlanta for more years than I care to remember, the wife and I decided to move to the country. Humming "Green Acres is the place for me..." we purchased a 29 acre tract about 60 miles south of Atlanta. Next came the house, I could talk about that ordeal for another two weeks... But, I want to talk about my tractor! We didn't even own a lawnmower, and all of a sudden we had enough grass to feed all the starving children of the bovine world. Naturally, I talked ... [Read Article]
Latest Ad: Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor [More Ads]
