Posted by Enar on September 30, 2010 at 13:40:57 from (98.244.241.123):
Well, day two of cranking my A has come and gone. I followed several of the suggestions I received. I took out each plug, put oil & a shot of starting fluid in each one. Didn't notice any gas on any of them. Took the lower half of the Zenith carb off and there is gas in the bowl. Blew brake cleaner through the little jets. Measured the distance the float is set at (perfect). (Applause not necessary) Sprayed SF in carb. Cranked a few times and it sputtered and turned over 3 or 4 times. Poured some gas into carb and cranked. It sputtered and coughed about the same as the SF. Repeated process several times to no avail. Am I missing something here?
BTW, the handle on my crank was broken at one time and welded. Now the weld is cracking or I should say the non-weld. Now I think I better go find a crank at Paquette's Historical Farmall Tractor Museum in Leesburg FL, about 10 miles from my home. Lucky me, I hope. Beautiful place. Over 80 Farmall's and IH's, all restored and running. And more being done all the time. As I said before, any help will be appreciated.
Today's Featured Article - A City Guy's First Tractor - by Fred Hambrecht. After living in apartments in Atlanta for more years than I care to remember, the wife and I decided to move to the country. Humming "Green Acres is the place for me..." we purchased a 29 acre tract about 60 miles south of Atlanta. Next came the house, I could talk about that ordeal for another two weeks... But, I want to talk about my tractor! We didn't even own a lawnmower, and all of a sudden we had enough grass to feed all the starving children of the bovine world. Naturally, I talked
... [Read Article]
Latest Ad:
Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor
[More Ads]
