JD 440 hydraulic pump
Don
08-04-2004 10:21:17
I had a similar problem on a 440 dozer with a backhoe. It had an obselete Cessna pump that I could not find specs for. I took a chance and replaced it with a 3.12 cu. in. Cessna pump from Surplus Center. It turned out to be a little bigger than the one it replaced but it worked out OK. The backhoe is a little faster now and sometimes it will kill the engine but ngenerally works fine. Hope this helps , Don
scott in wa
08-04-2004 11:10:28
 Re: JD 440 hydraulic pump in reply to Don, 08-04-2004 10:21:17
Yes thanks Don,
Do you remember what the specs were of the pump you bought, or maybe the model number???
thanks
scott
Don
08-04-2004 19:22:47
 Re: JD 440 hydraulic pump in reply to scott in wa, 08-04-2004 11:10:28
The pump is available at Surplus Center. It is Cessna model 25500 3.12 cu. inch with a 7/8" 13 spline shaft. I had to buy a 13 spline coupling and 1" 6 spline coupling which I cut in half and welded together to make a compatible coupling.The pump is $254.50 and the couplings are about $7.00 each plus shipping. Good luck Don
