FIXED??? new problem??
scott in wa.
04-22-2005 06:56:14
I changed the oil, blew out the crank case breather, and cleaned the breather on the valve cover.
Added some marvel mystery oil to it.
No more oil out the dip stick.
hummmmm m. Still not sure what’s going on.
But I do notice
Condensation or a bit more than that dripping from the breather ontop of the valve cover.
Almost like a slight amount of steam.
The oil in the crank case was clean not milky, just oily black.
Ran it an hour at 190 deg temp,
What do you think?
Scott
John Van Valkenburgh
04-22-2005 16:23:26
 Re: FIXED??? new problem?? in reply to scott in wa., 04-22-2005 06:56:14
Scott,
I'd run it and keep an eye on the engine temp, oil pressure, engine oil usage and coolant level. There will always be some crankcase pressure and if the breather was plugged its going to come out somewhere else.
Some condensation at the breather is normal, especially this time of year with temps going up and down a lot. The "steam" you see might be steam or it might be atomized oil particles from blowby. How much is normal is hard to say but blowby in and of itself is not going to damage anything. Running low on oil, coolant or overheating will. Excessive blowby will tend to pollute the engine oil a bit more quickly so keep up with the oil changes.
You asked if having excessive blowby would cause smoke or reduced engine performance. Its not likely to cause smoke in the exhaust. Technically the compression would be down a bit and this would reduce HP but perhaps not so much that you would notice.
A gradual increase in blowby over time is normal engine wear. A sudden increase in blowby (with no other obvious causes like a clogged breather) would tend to indicate that something has broken (a cracked piston or broken ring). In the case of a sudden increase in blowby, an engine tear-down in probably in order before something comes apart.
I hope this helps,
John
1968 Case 450
scott in wa.
04-23-2005 14:21:23
 Re: FIXED??? new problem?? in reply to John Van Valkenburgh, 04-22-2005 16:23:26
yes it does help.
I will keep an eye on it...
thanks
