ajk
02-21-2006 13:12:11
Sounds like that machine has done a bit of work,the leak from the extendahoe is probably coming from the cylinder inside the extendahoe housing or a ruptured pipe,repair that leak as you will find the extendahoe very useful,the oil leak by the pump you will have to pinpoint,could be the seal on the input shaft,loose or leaking pipe or a crack in the chassis as it doubles for the hyd oil reservoir,if its a crack get it welded,the valve for the swing should not fall down with the weight of the lever unless the spring that keeps the valve in the neutral position is broken or gone weak or the cap is loose,the spring is in the cap on the bottom end opposite from the valve,if the valve block is not leaking around the spools leave it alone,all that can be done with that block is replace the o"rings on the spools that catch the leak-by,the cylinders that are dropping are allowing the oil to bypass the pistons inside the cylinders and need resealing.hydraulic oil for the brakes,the engine is a Perkins 4.236 for the elbow.don"t know about the manual.
AJ
