Ok, I got a quote on the actual Manual from JCB .... get this $600 Canadian, I wanted the exact manual to verify correct piping to eliminate that aspect. Instead I found a machine near by with the same set up and have now validated the piping is correct. (remembering that when I got the machine the Extra dig was snapped in two and the entire backend was hydraulically disconnected. I will re verify the pressure indications tomorrow. I plan to measure at medium and high rpm, during actuation and monitor what the pressure jumps to when the cylinder is fully extended and pressure going over the MRV. I will check pressure on both the front loader (main fed from P1 side of the pump) valve and at the extra dig valve which feeds the main hoe valve body off of the P2 side of the pump. Yes the machine needs grease, but, I have also seen the thing KICK IN!! and its like a whole different piece of equipmnet (like a new wife or something, although I wouldn't know about that). I can't say what causes the hydraulics to kick in othere that it seems to do it when the machine warms up but only on occasion. -JRV says that the pump either works or doesn't -Another individual indicated that there are "O" rings in the Extra dig valve (which feeds the main Hoe Valve) and if the "O" rings are gone, I will get tons of blow by I feel better now after doing the A/B piping comparision to another machine. I'll report the pressure readings tomorrow, too dark to work, although I am keen to invest the time move closer to the problem, I think my pressure readings were off from earlier, I will validate them tomorrow. I like the Idea of the flow calculation, but, the cylinders may throuw the calculation off if the seals are a little worn... no? The point I'm trying to make is that when she kicks in it seems to have just incredible amounts of increased power, the difference is not minimal. If JRV is correct and he worked for JCB, the pump being a gear pump is fine. I need to go with his experience on that and assume that the pump is good for now. Then I can concentrate on the pressure readings and after that, I would like to start removing valve bodies and checking them. I have already completely disassembled and checked the MRV on the front bucket valve body, It seemed fine, but I suspect that I am NOT getting the 2000PSI I indicated earlier I think, I'll find more like 1200-1500PSI when the cylinder is fully extended. I am assuming that the MRV is the one on the front loader valve. Strange thing about this MRV, I turned the Allen key adjustment on top while the cylinder was maxed, and did not see a pressure increase/decrease that I expected to see. Thanks to all,
