Thanks.. one more thing...
sminnick
04-25-2006 04:41:20
Thanks. Still hoping is not the head gasket. I need to add that the engine was running smooth with no missing when the oil pressure dropped. One mechanic said that if it was the head gasket the engine would have sounded bad and lost power. Is there a way to check the oil cooler? Bob... is there a seal that could be bad between the water pump and the engine that could allow water in, even in the 953?
Bob/Ont
05-03-2006 18:35:11
 Re: Thanks.. one more thing... in reply to sminnick, 04-25-2006 04:41:20
Water pump will only leak externally. If there is no oil in the rad take the valve cover and oil pan off. Fill and pressurize the cooling system and watch for a leak.
Later Bob
