Still a good deal at $1850
jdemaris
12-09-2006 06:26:42
No, I did not look close. Why bother? I'm not nowhere near Florida so it's a moot point. As far as the vintage, it would make no difference to me. If I was buying a 450 series to fix up, I'd much rather have a dry-clutch dozer than a "C" or later wet clutch. We sold many Cs new, and the wet clutches have just as many problems as the dry - and cost more to fix. I find the older 450s with the HL-R shifter on the floor the easiest to work on - but I don't care for first engines. The 202 has low power and used straight conventional piston rings and piston grooves. Later engines have bigger bore and Keystone rings - they are much more durable. The seller says it's a B, and if so, it will have the bigger engine. But, there is no need for me to check. The seller also says it has a 6-way blade - but from the pictures it is an outside 4-way - not a 6-way. It also has loader tracks - not dozer. Regardless, it's a very good deal at $1850 - if I could get here for that price - which I cannot.
