Aspirator tube101
Bob/Ont
04-10-2007 06:41:23
You can check the aspirator tube for proper operation by taking off precleaner and running engine at high idle. The tube should draw like a vacume cleaner. If it doesn't you need to modify the end inside of the stack. Tube connection should enter stack and bend up 90 deg. The top end should be right even with the three tear drop pieces in the stack that form the venturi. That is what makes it draw.
Later Bob
