problem solved-JD450C revs up and down when working and t...
RussT
04-28-2008 08:40:15
I thought I had air getting into the fuel line because of the bubbles in the filter. The other day I noticed the ground wet under the tractor. It was from diesel fuel leaking from the fuel line. I removed the line and found a hole in it apparently caused by it rubbing against something. I replaced the line and it runs better than it has in a very long time. I don't know if it was sucking air through the hole or starving it for fuel but the new line fixed the problem.
Thanks,
RussT
