Use an analog meter.
Bob
10-20-2007 13:49:39
The noisy electrical systems on these old machines often give digital meters a sick headache.
Even a cheap analog meter is more than accurate enough for this use, and won't be affected by the EMI.
You want to see about 14.5 Volts on the large output stud, and the #1 and #2 terminals with the engine running.
With the engine STOPPED, the voltage on the #1 ("switched excite") terminal should drop to zero.
If it doesn't drop to zero, the alternator will remain "excited" and drain the battery.
