Coil
Bob
02-15-2008 20:16:38
If your setup has a "starting bypass", keep a 6-Volt coil and use a resistor.
If NO starting bypass (most likely), get a TRUE 12-Volt coil, such as the NAPA 14SB.
Incidently, there is NO "built-in resistor" in the TRUE 12-Volt coils, just MORE turns of wire in the primary winding.
ny bill
02-16-2008 04:27:05
 Re: Coil in reply to Bob, 02-15-2008 20:16:38
how do you tell if it has a "starting bypass"?
Bob
02-16-2008 08:47:46
 Re: Coil in reply to ny bill, 02-16-2008 04:27:05
The common way a starting bypass is set up is to run a run a wire from the "R" terminal on the starter solenoid (if so equipped) to the ignition switch side of the coil, so full battery voltage is sent to the coil while cranking, bypassing the ballast resistor.
