Correction on valve unshrouding
buickanddeere
10-30-2004 07:41:30
The cutter to cut the eyebrow back needs to be 1/2" large in dia to take 1/4" of metal off that is shrouding the intake valve. Don't go too large or you will hit water and also reduce head gasket sealing area between cylinders. The new edge should be radiused on the bottom and ground smooth to prevent cracking.
