Re: Hard Starting 1206
Posted by Lee K. on February 17, 2001 at 12:26:10 from (205.160.206.85):
In Reply to: Hard Starting 1206 posted by Chris on February 17, 2001 at 12:16:59:
A 1206 shouldn't start hard. Does it run alright other wise? Could have some nozzels that are that are dirty and need cleaning. Your pump shouldn't lose it's prime unless you have a seal out on the pump. You would notice a seal out if it is an external seal, because the pump would be covered with fuel, unless it is the pump drive shaft seal. If that was the case, you should be getting fuel in the engine oil. It might be possible to have a delivery valve on the pump that is stuck. What did the dealer do to check the pump? The only real way to really check out a pumps condition, is to send it in to a diesel shop and have them check it on a stand, but that will cost you a good sum of cash. Any body else have some ideas?
Post A Followup
: Re: Re: Hard Starting 1206
Today's Featured Article - Oliver 550 Purchaser Checklist - by Greg Sheppard. Pound for pound the 550 is better than anything I've seen. It has great power for its size and can really hunker down and lug. Classified as a 3-bottom plow depending on soil conditions. I personally don't think it can be beat for a utility tractor in the 40 HP range. They are extremely thrifty on fuel, at least my DSL is. Most drive train parts are fairly easy to get. Sheet metal is probably the hardest thing to ... [Read Article]
Latest Ad: 18-32 Case Cross Motor [More Ads]
