Farmall Tractors Discussion Board
Re: 706 clutch/pwr.str. problem
Posted by RickB. on January 31, 1999 at 05:38:46:
In Reply to: 706 clutch/pwr.str. problem posted by Lloyd on January 30, 1999 at 18:55:39:
I suspect it has a TA? Does the clutch problem occur if the TA is in low? The steering, brakes, and direct drive clutch pack in the TA are all supplied and controlled by a valve body with a small pump bolted to it on the left side of the transmission below the deck. This pump is independent of the pump which supplies oil to the hitch & aux. circuits. I suspect you have problems there, such as bad pump, loose drive gear, stuck spool in the valve body, or a blown gasket in the valve body. You also could have a plugged orfice in the steering supply, along with a bad main clutch. Best to buy a service manual, or get someone with experience to test the MCV circuits.
Post a Followup
: Re: Re: 706 clutch/pwr.str. problem
Today's Featured Article - A Brief History of Tractors in Australia - by Bob Kavanagh. After Captain Cook's exploration of the east coast in 1770 the British Government decided to establish a penal colony in Australia. The first fleet arrived in 1788 and consisted mainly of convicts who were poorly equipped and new little of farming techniques. The colony remained far from self-supporting and it was not until the early 1800's that things started to improve. Free settlers started to arrive, they followed the explorers across the mountains and where land was suitable set up farms. T ... [Read Article]
Latest Ad: Sell 1958 Hi-Altitude Massey Fergerson tractor, original condition. three point hitch pto engine, Runs well, photos available upon request [More Ads]
