Re: Re: Re: Carburetor- Carter UT
Posted by haas on February 22, 2001 at 05:50:59 from (129.37.117.227):
In Reply to: Re: Re: Carburetor- Carter UT posted by Bob/Maine on February 22, 2001 at 04:31:02:
That's the way with these old tractors. You fix one thing and then you find something else and before you know it, you've been through the whole thing and spent a bunch of money! Have you checked the fluid level in the hydraulic system?? Also, if it is cold there may be some ice in there stopping things up. Does it load the tractor engine when you move the levers?? If so, I doubt it's the pump.
Post A Followup
: Re: Re: Re: Re: Carburetor- Carter UT
Today's Featured Article - Oliver 550 Purchaser Checklist - by Greg Sheppard. Pound for pound the 550 is better than anything I've seen. It has great power for its size and can really hunker down and lug. Classified as a 3-bottom plow depending on soil conditions. I personally don't think it can be beat for a utility tractor in the 40 HP range. They are extremely thrifty on fuel, at least my DSL is. Most drive train parts are fairly easy to get. Sheet metal is probably the hardest thing to ... [Read Article]
Latest Ad: 18-32 Case Cross Motor [More Ads]
