HELP, The Farmall C I purchased a couple months ago OVERHEATS
Posted by Kurt on May 05, 2001 at 18:30:04 from (204.233.241.120):
Need advice: I purchased a restored C a couple months ago and I just got around to hooking up a 6ft. mower to it and trying to use it. After mowing around 1 acre in 60 degree weather, the radiator boils over. I was mowing in first gear, not lugging, and not tall grass. The tractor was not working very hard. Temp gauge doesn't work I found out. I'm new to Farmalls and this one doesn't have a water pump. Someone told me it's possible my radiator could be too full and the engine boils water to circulate. If it's too full it will boil it out to get equilibrium? I removed the radiator cap and the coolant was 230 degrees with a thermometer. Fan belt is tight and shutters are open. What do I do? Please advise. Thanks
Post A Followup
: Re: HELP, The Farmall C I purchased a couple months ago OVERHEATS
Today's Featured Article - Oliver 550 Purchaser Checklist - by Greg Sheppard. Pound for pound the 550 is better than anything I've seen. It has great power for its size and can really hunker down and lug. Classified as a 3-bottom plow depending on soil conditions. I personally don't think it can be beat for a utility tractor in the 40 HP range. They are extremely thrifty on fuel, at least my DSL is. Most drive train parts are fairly easy to get. Sheet metal is probably the hardest thing to ... [Read Article]
Latest Ad: 18-32 Case Cross Motor [More Ads]
