Re: Repairing groove in shaft from oil seal?
Posted by D Smoker on May 06, 2001 at 05:25:00 from (64.41.22.224):
In Reply to: Repairing groove in shaft from oil seal? posted by Lowell Davis on May 06, 2001 at 04:48:47:
I've gotten away with putting a few on backwards with the flange outwards and then removing the flange and very carefully filing the edge of the sleeve. This only works if the fit is not exceedingly tight (use loctite on the shaft under the sleeve, if you try this). The Speedy Sleeves also come in various widths, the other possiblity is to get a narrower sleeve. I've never had any luck filling with an epoxy in a seal groove. If you have room you can always set the seal higher or lower than the groove.
Post A Followup
: Re: Re: Repairing groove in shaft from oil seal?
Today's Featured Article - Oliver 550 Purchaser Checklist - by Greg Sheppard. Pound for pound the 550 is better than anything I've seen. It has great power for its size and can really hunker down and lug. Classified as a 3-bottom plow depending on soil conditions. I personally don't think it can be beat for a utility tractor in the 40 HP range. They are extremely thrifty on fuel, at least my DSL is. Most drive train parts are fairly easy to get. Sheet metal is probably the hardest thing to ... [Read Article]
Latest Ad: 18-32 Case Cross Motor [More Ads]
