Re: Re: Re: electrical system on 464
Posted by Bob M on May 24, 2001 at 10:31:59 from (192.232.119.194):
In Reply to: Re: Re: electrical system on 464 posted by Gene on May 24, 2001 at 09:07:23:
Gene - 7 volts across the coil with the motor stopped says there's a ballast resistor somewhere in the primary circuit, the coil is 6 volt rated, and everything is as it should be. Fouling the plugs after it warms up however says the carb is set too rich, the motor's burning oil or the plugs are too cold. Suggest switching to plugs one or two heat ranges hotter and making sure the carb is set properly. Keep in mind also the lousy gasoline we get today seems highly prone to soot-foul spark plugs unless an engine is worked hard. Again the solution is to switch to plugs a couple heat ranges higher. Good luck!
Home
| Forums
Today's Featured Article -
Oliver 550 Purchaser Checklist - by Greg Sheppard. Pound for pound the 550 is better than anything I've seen. It has great power for its size and can really hunker down and lug. Classified as a 3-bottom plow depending on soil conditions. I personally don't think it can be beat for a utility tractor in the 40 HP range. They are extremely thrifty on fuel, at least my DSL is. Most drive train parts are fairly easy to get. Sheet metal is probably the hardest thing to
... [Read Article]
Latest Ad:
18-32 Case Cross Motor
[More Ads]
Copyright © 1997-2025 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
