Re: Common IH 656 three point hitch problems
Posted by Hugh MacKay on March 15, 2009 at 02:13:36 from (216.208.58.136):
In Reply to: Common IH 656 three point hitch problems posted by benjamin C. on March 14, 2009 at 16:38:07:
Benjamin: I ran my 656, 15,000 hours and the hitch never failed. If there is a problem it must be operators of tractor's past.
Today's Featured Article - Product Review: Lead Substitutes - by Mike Schordine. Lead was oriinally added to gasoline as an upper cylinder lubricant. It lubes the valves and seats. If you rebuild the motor, you could use hardened seats and valves, and unleaded fuel. But if your old tractor runs good, a simple lead substitute added to the gas is a perfectly reasonable solution. And, if you are like me, your tractor is under cover, but it sits outside. So with every temperature change, the humidity in the air collects in the fuel tank, in the form of water. ... [Read Article]
Latest Ad: Sell 1958 Hi-Altitude Massey Fergerson tractor, original condition. three point hitch pto engine, Runs well, photos available upon request [More Ads]
