Re: trouble still with m carb...
Posted by Dan on June 13, 2001 at 21:50:53 from (12.18.158.25):
In Reply to: trouble still with m carb... posted by kevin on June 13, 2001 at 17:45:46:
I think I would replace the float. IH dealer should be able to get them along with a lot of after market places that advertise in Red Power Magazine. You might also check float setting, should be 1 5/16 inch from bottom of casting to low point of float in shut off position. Other thing is sometimes the float will hang up on the center part of the carburator so check that. The pin the float swings on sometimes gets worn also and causes it to bind. I got a carb kit from Napa and found the needle and seat supplied was shorter than the old one. Good luck on it. They are a bit pesky to get set right.
Post A Followup
: Re: Re: trouble still with m carb...
Today's Featured Article - Oliver 550 Purchaser Checklist - by Greg Sheppard. Pound for pound the 550 is better than anything I've seen. It has great power for its size and can really hunker down and lug. Classified as a 3-bottom plow depending on soil conditions. I personally don't think it can be beat for a utility tractor in the 40 HP range. They are extremely thrifty on fuel, at least my DSL is. Most drive train parts are fairly easy to get. Sheet metal is probably the hardest thing to ... [Read Article]
Latest Ad: 18-32 Case Cross Motor [More Ads]
