Re: charging woes
Posted by gene b on June 23, 2001 at 20:10:56 from (63.25.166.56):
In Reply to: charging woes posted by joe on June 23, 2001 at 12:06:28:
hoof up positive ground as that is the way it is supposed to be your reg will not work as the reverse current coil is set for positive ground polarize the gen by touching bat ttterm to arm term just to draw a spark that is enough if it wont charge then ground the field if it still wont charge the gen is bad you have probably ruined the reg by using neg ground but you might have beenlucky
Post A Followup
: Re: Re: charging woes
Today's Featured Article - Third Brush Generators - by Chris Pratt. While I love straightening sheet metal, cleaning, and painting old tractors, I use every excuse to avoid working on the on the electrics. I find the whole process sheer mystery. I have picked up and attempted to read every auto and farm electrics book with no improvement in the situation. They all seem to start with a chapter entitled "Theory of Electricity". After a few paragraphs I usually close the book and go back to banging out dents. A good friend and I were recently discussing our tractor electrical systems when he stated "I figure it all comes back to applying Ohms Law". At this point ... [Read Article]
Latest Ad: 18-32 Case Cross Motor [More Ads]
