Oil pressure M diesel
Posted by Paul on July 07, 2001 at 06:59:51 from (172.156.137.8):
Thinking about buying a diesel m that was stuck have got it unstuck and have some questions about primming oil pump and how much trouble am I going to run into with the injector pump and filter with old fuel. Pulled the rod bearing inserts and the crank and bearings look fine. felt of sleeves and no wear noted. I have a w4 that i brush hog with and am very happy with. had a JD mt that didn't have enough power. thanks for response I do have a IT shop manual.
Post A Followup
: Re: Oil pressure M diesel
Today's Featured Article - Oliver 550 Purchaser Checklist - by Greg Sheppard. Pound for pound the 550 is better than anything I've seen. It has great power for its size and can really hunker down and lug. Classified as a 3-bottom plow depending on soil conditions. I personally don't think it can be beat for a utility tractor in the 40 HP range. They are extremely thrifty on fuel, at least my DSL is. Most drive train parts are fairly easy to get. Sheet metal is probably the hardest thing to ... [Read Article]
Latest Ad: 18-32 Case Cross Motor [More Ads]
