Wiring Diagram 1948 Farmall
Posted by Reagon Wright on July 28, 2001 at 15:53:12 from (204.17.220.89):
The Diagram I recieved shows Positive Battery Cable going to frame and Negative going to starter. IS THIS CORRECT???? I am looking for another diagram that may help to clear up the proper wiring problems. All wires are now replaced but cant figure out where they go back to. When I connect the wires the Battery Posts Smoke when I turn the Key. Starter does not turn but Silinoid does activate. Starter was checked out and works fine off the tractor. Desperatly need tracter running. All advice will be helpful! Thanks!
Post A Followup
: Re: Wiring Diagram 1948 Farmall
Today's Featured Article - Oliver 550 Purchaser Checklist - by Greg Sheppard. Pound for pound the 550 is better than anything I've seen. It has great power for its size and can really hunker down and lug. Classified as a 3-bottom plow depending on soil conditions. I personally don't think it can be beat for a utility tractor in the 40 HP range. They are extremely thrifty on fuel, at least my DSL is. Most drive train parts are fairly easy to get. Sheet metal is probably the hardest thing to ... [Read Article]
Latest Ad: 18-32 Case Cross Motor [More Ads]
