Re: converting Super M to 12 volt wiring voltage regulator
Posted by The Red on September 09, 2001 at 04:17:20 from (12.84.239.94):
In Reply to: converting Super M to 12 volt wiring voltage regulator posted by Carl on September 08, 2001 at 21:37:40:
Carl you will have to pull the light box apart to make sure you get the correct wire to the correct post on the VR. One wire should go from the bat. terminal to the negative post on the ampmeter. The other wire possibly goes from the L terminal on the VR to the junction box in the light box. That junction box will have both a wire going to the light switch, via the fuse, and another wire to the coil switch. The bat. terminal should be the center post of the three. You do not have to wire the lights and coil switch using the L terminal. You can run both wires off the negative side of the ampmeter which was how the early Hs and Ms were wired.
Home
| Forums
Today's Featured Article -
Oliver 550 Purchaser Checklist - by Greg Sheppard. Pound for pound the 550 is better than anything I've seen. It has great power for its size and can really hunker down and lug. Classified as a 3-bottom plow depending on soil conditions. I personally don't think it can be beat for a utility tractor in the 40 HP range. They are extremely thrifty on fuel, at least my DSL is. Most drive train parts are fairly easy to get. Sheet metal is probably the hardest thing to
... [Read Article]
Latest Ad:
18-32 Case Cross Motor
[More Ads]
Copyright © 1997-2025 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
