Re: 1086 rear crank seal
Posted by the tractor vet on September 09, 2001 at 21:56:46 from (216.196.12.123):
In Reply to: 1086 rear crank seal posted by Charlie Stitt on September 09, 2001 at 19:20:53:
The tractor must be split at the bell houseing and the clutch and flywheel must be removed , then you remove the seal and ware ring . To reinstall you should have the seal installer to do the job , the seal is not cheep and you don't want to screw it up . Most times it is best left to the profesonals. It takes about 5 to 6 hours to do with one man and while you are in there it is best to replace the input and PTO seal and check for ware on the PTO input shaft and the clutch , Alot of times it is the pto that is leaking and not the rear main seal.
Post A Followup
: Re: Re: 1086 rear crank seal
Today's Featured Article - Oliver 550 Purchaser Checklist - by Greg Sheppard. Pound for pound the 550 is better than anything I've seen. It has great power for its size and can really hunker down and lug. Classified as a 3-bottom plow depending on soil conditions. I personally don't think it can be beat for a utility tractor in the 40 HP range. They are extremely thrifty on fuel, at least my DSL is. Most drive train parts are fairly easy to get. Sheet metal is probably the hardest thing to ... [Read Article]
Latest Ad: 18-32 Case Cross Motor [More Ads]
