carb on a td9
Posted by Lynn Miller on September 10, 2001 at 17:44:16 from (209.23.148.49):
I have an early TD9 that has had problems starting. Found out that the head gasket is blown between 2&3. I took the carb apart thinking my trusty engine manual would tell me the setting for the venturi disc. What I am refering to is the phenolic disc with the spring under it and a long stem brass nut with four slots cut in it for a cotter pin. It appears that the disc can be adjusted anywhere from tight to the carb body to about 1/4" gap. I suspect that somewhere in between would be the correct setting. By the way, I am having the head magna-fluxed to see if there are any of those nasty cracks I have read so much about. Lynn
Post A Followup
: Re: carb on a td9
Today's Featured Article - Oliver 550 Purchaser Checklist - by Greg Sheppard. Pound for pound the 550 is better than anything I've seen. It has great power for its size and can really hunker down and lug. Classified as a 3-bottom plow depending on soil conditions. I personally don't think it can be beat for a utility tractor in the 40 HP range. They are extremely thrifty on fuel, at least my DSL is. Most drive train parts are fairly easy to get. Sheet metal is probably the hardest thing to ... [Read Article]
Latest Ad: 18-32 Case Cross Motor [More Ads]
