Hand Clutch problems
Posted by Dave on September 14, 2001 at 00:33:28 from (66.81.19.140):
I've gotten my 1940 M-D O-4 running pretty well, except that the over center hand clutch won't go over center and stay engaged. I've opened the bottom plate, released the locking tab and "attempted" to turn the adjusting disk with no luck yet. The manual says to turn clockwise to adjust, and not to create "too much resistance" to engagement. Since that is what I've got, should I try to go counterclockwise? Any good tricks for moving the adjusting disk? Does this type of problem mean the clutch is almost worn out? (Doesn't feel like it, as if I hold it, it bites and everything moves along well in any gear.) Any help or advice greatly appreciated.
Thanks.
Dave.
Post A Followup
: Re: Hand Clutch problems
Today's Featured Article - Oliver 550 Purchaser Checklist - by Greg Sheppard. Pound for pound the 550 is better than anything I've seen. It has great power for its size and can really hunker down and lug. Classified as a 3-bottom plow depending on soil conditions. I personally don't think it can be beat for a utility tractor in the 40 HP range. They are extremely thrifty on fuel, at least my DSL is. Most drive train parts are fairly easy to get. Sheet metal is probably the hardest thing to ... [Read Article]
Latest Ad: 18-32 Case Cross Motor [More Ads]
