how can i tell if its charging?
Posted by Jeff on September 16, 2001 at 15:45:58 from (134.126.188.86):
I put my newly rewired generator on my M yesterday and it starts it up really nice. It was switched to negative ground and 12 volts. The only problem is, i cannot tell whether or not it is charging correctly. i am hoping of course that it is but i think i may have messed up my ampmeter while trying to take the plate it is mounted to off. one of the screws was messed up so i had to saw it off and i got impatient and tried knocking it off with a chisel and hammer. i know now this was a bad idea when i saw the needle stuck in the full discharge position (its there when the tracotor is running or stopped). so what could i do to find out if the generartor is charging correctly without buying a new ampmeter (i am going to do that some day i just want to know something else that would work right now). i polarized the generator and i think everything should be hooked up correctly. thanks for the help!
jeff
Post A Followup
: Re: how can i tell if its charging?
Today's Featured Article - Oliver 550 Purchaser Checklist - by Greg Sheppard. Pound for pound the 550 is better than anything I've seen. It has great power for its size and can really hunker down and lug. Classified as a 3-bottom plow depending on soil conditions. I personally don't think it can be beat for a utility tractor in the 40 HP range. They are extremely thrifty on fuel, at least my DSL is. Most drive train parts are fairly easy to get. Sheet metal is probably the hardest thing to ... [Read Article]
Latest Ad: 18-32 Case Cross Motor [More Ads]
