Re: F-14 rear rubber
Posted by Bob Kerr on September 17, 2001 at 15:39:27 from (205.188.195.23):
In Reply to: F-14 rear rubber posted by JDM on September 16, 2001 at 07:00:29:
Keep in mind that your F-14 has a thermosiphon cooling system and if the front end of the tractor is too low it can cause the rear of the head to overheat and warp or crack. Also call around to some AG tire stores. If miller has a tire size listed then you can get the same size tire locally but you will most likely have to order it in. You also won't have to pay shipping! I got 9.50 x 36 tires for my f-12 for $210 and that was with tubes from a small local tire store out in the sticks.
Post A Followup
: Re: Re: F-14 rear rubber
Today's Featured Article - Oliver 550 Purchaser Checklist - by Greg Sheppard. Pound for pound the 550 is better than anything I've seen. It has great power for its size and can really hunker down and lug. Classified as a 3-bottom plow depending on soil conditions. I personally don't think it can be beat for a utility tractor in the 40 HP range. They are extremely thrifty on fuel, at least my DSL is. Most drive train parts are fairly easy to get. Sheet metal is probably the hardest thing to ... [Read Article]
Latest Ad: 18-32 Case Cross Motor [More Ads]
