Re: BAD FLOAT??
Posted by Bill Smith on September 22, 2001 at 12:30:10 from (128.242.4.59):
In Reply to: BAD FLOAT?? posted by THatOtherGuy on September 20, 2001 at 18:28:26:
You should be able to find a setiment bowl in a salvage yard for little or nothing. Any H setiment bowl will work. As for your carb problem when it is leaking fuel out the bottom of carb, shut the fuel valve off under the gas tank. There should be a gas shut off valve just above the setiment bowl on an original setiment bowl assembly. (Not sure if you are missing the valve as well as the setiment bowl.) This will keep fuel from running out of tank and onto ground. Don't try running the tractor with this carb problem becuase you air fuel mixure for engine is way to rich. Your carb problem is one of the following. Bad shut off needle valve in carb, or a hole in the float allowing it to sink, a stuck float or valve, wrong fuel level adjusted by float, or I have had the pin that the float hinges on work its way out of one of the holes. The pin should be placed in the holes and then crimped so it will stay. You will have to take carb apart and inspect it to see what is causing the valve to not shut off.
Post A Followup
: Re: Re: BAD FLOAT??
Today's Featured Article - Oliver 550 Purchaser Checklist - by Greg Sheppard. Pound for pound the 550 is better than anything I've seen. It has great power for its size and can really hunker down and lug. Classified as a 3-bottom plow depending on soil conditions. I personally don't think it can be beat for a utility tractor in the 40 HP range. They are extremely thrifty on fuel, at least my DSL is. Most drive train parts are fairly easy to get. Sheet metal is probably the hardest thing to ... [Read Article]
Latest Ad: 18-32 Case Cross Motor [More Ads]
