Auxillary Hydraulic Valve on M with live hyd
Posted by Dick Davis on September 22, 2001 at 16:28:48 from (152.163.204.52):
Did a little fall disking and found hydraulic fluid pouring out of the auxillary hydraulic valve! It is coming from both sides of the opening where the cross shaft passes through the top of the valve body. Does anyone know, are there o rings on this shaft or is it a weld up and grind down to fit seal? An exploded view of the aux valve would be very appreciated, Dick
Post A Followup
: Re: Auxillary Hydraulic Valve on M with live hyd
Today's Featured Article - Oliver 550 Purchaser Checklist - by Greg Sheppard. Pound for pound the 550 is better than anything I've seen. It has great power for its size and can really hunker down and lug. Classified as a 3-bottom plow depending on soil conditions. I personally don't think it can be beat for a utility tractor in the 40 HP range. They are extremely thrifty on fuel, at least my DSL is. Most drive train parts are fairly easy to get. Sheet metal is probably the hardest thing to ... [Read Article]
Latest Ad: 18-32 Case Cross Motor [More Ads]
