Re: Re: Re: What would extra options would you buy for your H or M?
Posted by Stan(VA). on December 12, 2001 at 15:42:55 from (207.172.180.58):
In Reply to: Re: Re: What would extra options would you buy for your H or M? posted by john d - clutch improvement on December 12, 2001 at 06:39:46:
Thanks for the post John,
Is it possible to get a picture of one of these arms? Are you talking about what is called the "clutch release shaft with lever" in the parts book? If so, did it replace the lever on that shaft, or just clip to it and extend it farther down?
Stan(VA).
PS - C.E. M&W is still in business in IL, making farm equipment, just not handling everything they once did. I understand they sold off some lines over the years (ie: piston/sleeve and stroker crank kits). They will still send out a copy of the operators manual for the hand clutch with a parts breakdown.
Post A Followup
: Re: Re: Re: Re: What would extra options would you buy for your H or M?
Today's Featured Article - Oliver 550 Purchaser Checklist - by Greg Sheppard. Pound for pound the 550 is better than anything I've seen. It has great power for its size and can really hunker down and lug. Classified as a 3-bottom plow depending on soil conditions. I personally don't think it can be beat for a utility tractor in the 40 HP range. They are extremely thrifty on fuel, at least my DSL is. Most drive train parts are fairly easy to get. Sheet metal is probably the hardest thing to ... [Read Article]
Latest Ad: 18-32 Case Cross Motor [More Ads]
