Farmall 300 valve train noise(?)
Posted by James (MO) on December 27, 2001 at 13:27:02 from (4.48.59.234):
When my 300 idles, it makes a clattering noise which sounds like the valves need adjustment. At half throttle or higher, no such noise can be heard. The valves are properly adjusted. I took the rocker shaft assembly off & disassembled it. Shaft looks fine, a small amount of wear can be seen on the inside of the rocker arm bearings. Is there a simple fix for this? Can what appears to be bushings be replaced? I would appreciate experiences, opinions, and recommendations of you fellas who have been thru this. (Maybe it's not really valve train noise!)
Post A Followup
: Re: Farmall 300 valve train noise(?)
Today's Featured Article - Oliver 550 Purchaser Checklist - by Greg Sheppard. Pound for pound the 550 is better than anything I've seen. It has great power for its size and can really hunker down and lug. Classified as a 3-bottom plow depending on soil conditions. I personally don't think it can be beat for a utility tractor in the 40 HP range. They are extremely thrifty on fuel, at least my DSL is. Most drive train parts are fairly easy to get. Sheet metal is probably the hardest thing to ... [Read Article]
Latest Ad: 18-32 Case Cross Motor [More Ads]
