Re: tractor for Amputee,again and thanks!
Posted by Bob M - another idea on January 05, 2002 at 08:23:45 from (66.66.72.246):
In Reply to: tractor for Amputee,again and thanks! posted by JDM on January 05, 2002 at 06:36:14:
JDM - Here's another thought: The IHC O- and W- series tractors could be ordered with an over-center (hand) clutch. Clutch was operated by a hand lever to the driver's right - same as 2 on cyl Deere tractors. The O-6 and W-6 use the same engine and clutch housing as the Farmall M - I would think an over-center clutch from an O-6, OS-6 or W-6 (also from a T-6 crawler, and possibly a U-6 power unit...) could be retrofitted to your friend's M.
Suspect this would probably be a pretty much a "bolt up" conversion to the M. It would retain exising independent wheel brakes pedals on the right foot making it easier/safer for others besides your amputee friend operate.
Just an idea...
Post A Followup
: Re: Re: tractor for Amputee,again and thanks!
Today's Featured Article - Oliver 550 Purchaser Checklist - by Greg Sheppard. Pound for pound the 550 is better than anything I've seen. It has great power for its size and can really hunker down and lug. Classified as a 3-bottom plow depending on soil conditions. I personally don't think it can be beat for a utility tractor in the 40 HP range. They are extremely thrifty on fuel, at least my DSL is. Most drive train parts are fairly easy to get. Sheet metal is probably the hardest thing to ... [Read Article]
Latest Ad: 18-32 Case Cross Motor [More Ads]
