Need Help with Fluid specs for IH 350 Utility
Posted by Ken on January 05, 2002 at 14:17:34 from (4.4.187.59):
I'm in the process of changing the transmission fluid in my 350 utility (seems there was a little water in it and living in Minnesota, water has a tendency to take on a solid form). Anyway, the local IH dealer says it calls for 7 gal of 80/90. Is this correct? I purchased the lube from a local supply company and it appears to be a bit thicker than what came out of the unit. I just want to be sure before I start dumping it in.
Thanks in advance,
Ken
Post A Followup
: Re: Need Help with Fluid specs for IH 350 Utility
Today's Featured Article - Oliver 550 Purchaser Checklist - by Greg Sheppard. Pound for pound the 550 is better than anything I've seen. It has great power for its size and can really hunker down and lug. Classified as a 3-bottom plow depending on soil conditions. I personally don't think it can be beat for a utility tractor in the 40 HP range. They are extremely thrifty on fuel, at least my DSL is. Most drive train parts are fairly easy to get. Sheet metal is probably the hardest thing to ... [Read Article]
Latest Ad: 18-32 Case Cross Motor [More Ads]
