Farmall Tractors Discussion Board
Re: International 240 Utility info
Posted by Harold H on March 24, 1999 at 17:51:34:
In Reply to: International 240 Utility info posted by Gary on March 23, 1999 at 19:16:35:
Gary,
The Farmall 240 and International 240 have the same basic drive train but a complete different configuration. The Farmall is a high profile row crop tractor. It has a flat transmission top and the seat is high on top of this. The rear axles are long and the rear wheels clamp to the axle so they can slide for different row spacing. The standard rear wheels are 36". Tricycle front was standard with single front or wide front axle optional. If the Farmall was equipped with a wide front axle, it still had the tricycle bolster and a steering arm was attached where the normal tricycle front was mounted. The International is of a low profile design. The front blolster is designed to work with the wide front axle only. It has a shorter wheelbase than the Farmall. The rear wheels are mounted to flanges on the rear axles. The standard wheels are 28". The rear end is designed where the operator sits straddle of the transmission in a much lower position than on the Farmall. Although both tractors have the same drive train, they were tested seperately at Nebraska. The Farmall 240 test #667 CHP 28.87 db hp, 32.22 pto hp; International 240 test #668 CHP 28.91 db hp, 32.24 pto hp. The standard Farmall shipping weighe is 3360 lbs and the standard International shipping weigh is 3099 lbs. Both tractors have live hydraulics, available with o, 1, or 2 auxilary valves, and were available with 2-point or 3-point hitch. The tractor was introduced in late 1958 and was built 58, 59, 60, and 61. The 240 was a continuing evolution of the Super C line and is a very good tractor. Price depends on area. Hope this information helps.
Harold H
Post a Followup
: Re: Re: International 240 Utility info
Today's Featured Article - Third Brush Generators - by Chris Pratt. While I love straightening sheet metal, cleaning, and painting old tractors, I use every excuse to avoid working on the on the electrics. I find the whole process sheer mystery. I have picked up and attempted to read every auto and farm electrics book with no improvement in the situation. They all seem to start with a chapter entitled "Theory of Electricity". After a few paragraphs I usually close the book and go back to banging out dents. A good friend and I were recently discussing our tractor electrical systems when he stated "I figure it all comes back to applying Ohms Law". At this point ... [Read Article]
Latest Ad: 18-32 Case Cross Motor [More Ads]
