Posted by spiffy1 on March 17, 2009 at 07:25:36 from (70.41.137.72):
Just curious here; does anyone know if the codes on 22-36 pistons and sleeves were date codes, size variants, or something else?
Both the original and new ones I put in are Rev D; however, the pistons & sleeves in the original were also stamped A, so were the pistons (which had a B stamp, but clearly stamped over A) while the new ones stamped D.
One of the new sleeves had a flat side [must have been a defective one, fell off the truck, or was run over, or something] and was not going to take a piston..... maybe there is some pursuation that would have made it round again, but I had prepped two old sleeves that were in my comfort level anyway [slight visual scoring after honing, but nothing you could feel; maybe .012 over; ridge reamer took care of the top - but I didn't recall them being so hard!], so just dropped one of them in instead.
Anyway, the new piston feels great in there, and nothing really measured different from what I could tell, so was just curious what the marks indicated.
Oh, it's no longer decapitated, but would likely appreciate a manifold and carb.
I lubed the ring compressor [I know you don't need it, but using that from the top, I could just shove ringless pistons right up, instead of applying the little extra force the taper required with rings on] good with some 10wt, and it shows on the sleeves; yet enough ring drag, I need the crank to turn it (pulling the crankshaft through the handholes does still, do it, but my face likely turns purple): I think the rings will seat great. Oh, music to my ears too hearing air come out the sparkplug holes when cranked. Not a surprise - I do have more faith in my work than that :lol: but when it showed up here, I tried the aircompressor on each piston, and air came out so many directions at once I didn't know what was up [6 open valves, and cross talk for at least two if not all three locations].
Today's Featured Article - Oliver 550 Purchaser Checklist - by Greg Sheppard. Pound for pound the 550 is better than anything I've seen. It has great power for its size and can really hunker down and lug. Classified as a 3-bottom plow depending on soil conditions. I personally don't think it can be beat for a utility tractor in the 40 HP range. They are extremely thrifty on fuel, at least my DSL is. Most drive train parts are fairly easy to get. Sheet metal is probably the hardest thing to
... [Read Article]
