Re: SC carburator
Posted by Farmall Bob on March 18, 2009 at 05:44:44 from (24.31.158.92):
In Reply to: SC carburator posted by B Kyle on March 17, 2009 at 18:56:22:
Hi B-Kyle,
I am working on mine at this time and have been getting plenty of help. You may want to check on down through the forum to receive the messages.
I do let my carburetor soak in a coffee can of old gas over night or two. Then using a small stiff brush (usually with the brush end cut in half)clean all that you can. Then with an air nossel blow out the ports/injectors both ways.
Mine is a Carter U and I am not happy with it as it leaks, but it does work. After reading the helpful suggestion have found out why it leaks. Where the valve set and valve come together isn't a good fit. Get your carburetor into the sunlight and check the valve set. The small hole in mine isn't round so the valve can't 100% close off the gas. Hope this helps and not complicate your situation. I do have a couple of Zeniths kicking around if need be and they are a little better carb.
Bob
Today's Featured Article - The River Tractor - by Charlie English Jr.. This is a 4010 John Deere that was used to farm on the Diamond Island which is in the Ohio River about 15 miles southwest of Evansville, Indiana. About ten years ago, this tractor was parked close to the bank as the river was washing the bank of the island away. ... [Read Article]
Latest Ad: 1945 Farmall wide body gas with pto and front plow. Runs good but needs new points. [More Ads]
