Re: Oil leak on Farmall C
Posted by riverbend on February 20, 2007 at 19:24:01 from (208.160.33.20):
In Reply to: Oil leak on Farmall C posted by Vacherie on February 20, 2007 at 19:07:48:
If the oil is coming from above the plugs, you might need a new valve cover gasket. The head gasket is located below the spark plugs. When you do the next tune up and adjust the valves, replace the v/c gasket. When you have the cover off check to see that the oil drains are clear. In the mean time, just keep an eye on the oil level.
Greg
Today's Featured Article - Oliver 550 Purchaser Checklist - by Greg Sheppard. Pound for pound the 550 is better than anything I've seen. It has great power for its size and can really hunker down and lug. Classified as a 3-bottom plow depending on soil conditions. I personally don't think it can be beat for a utility tractor in the 40 HP range. They are extremely thrifty on fuel, at least my DSL is. Most drive train parts are fairly easy to get. Sheet metal is probably the hardest thing to ... [Read Article]
Latest Ad: 18-32 Case Cross Motor [More Ads]
