Re: Farmall 460 rear main bearing clip
Posted by Owen Aaland on February 25, 2007 at 00:33:53 from (65.165.246.11):
In Reply to: Farmall 460 rear main bearing clip posted by Chester T Welte on February 24, 2007 at 23:25:09:
Are you talking about the tabs on the bearings not fitting into the block and cap or are you trying to assemble the cap to the block with the tabs on the sme side of the block?
The assembling of mains on these engines is diffrerent than most other engines. The main tabs assemble into the block 180 degrees apart. Also the arrow on the cap should point to the front of the engine.
If the bearings do not fit the block and cap then you have the wrong bearings for your engine.
There was a change in main bearings during the production run of that series of tractors that delt with the OD of the thrust bearing. The later engines use a larger bearing. If this is the bearing that is causing the problem make sure if you have the larger bearing that the block is machined to accept that size other wise you will need to get the smaller bearing.
Today's Featured Article - Third Brush Generators - by Chris Pratt. While I love straightening sheet metal, cleaning, and painting old tractors, I use every excuse to avoid working on the on the electrics. I find the whole process sheer mystery. I have picked up and attempted to read every auto and farm electrics book with no improvement in the situation. They all seem to start with a chapter entitled "Theory of Electricity". After a few paragraphs I usually close the book and go back to banging out dents. A good friend and I were recently discussing our tractor electrical systems when he stated "I figure it all comes back to applying Ohms Law". At this point ... [Read Article]
Latest Ad: 18-32 Case Cross Motor [More Ads]
