Re: 1466 Power Steering
Posted by Jay IH Man on February 25, 2007 at 17:22:46 from (69.149.149.53):
In Reply to: 1466 Power Steering posted by Steve Mahac on February 25, 2007 at 10:02:06:
First find a 5/8 wrench and remove the only plug on the MCV valve located on the left hand side of unit, the plug is towards the rear of tractor.
There is only one that is 5/8,this opens the steering orfice,crank over tractor with plug removed,this is messy and will shoot oil out of unit after a short time.when you have a steady stream replace plug and you will have steering. If you use this unit in cold weather go to your Case dealer and purchase a hyd. suction sreen for a 7100 series magnum tractor. Grind off rubber gasket to the same size of your hyd filter that you have removed.Install the suction screen instead of filter and this will help you in winter time operation. We have done this for customers that have slow or no hyds. in cold weather,this works on 06,26,56,66,86,88 series tractors as well.
Today's Featured Article - Third Brush Generators - by Chris Pratt. While I love straightening sheet metal, cleaning, and painting old tractors, I use every excuse to avoid working on the on the electrics. I find the whole process sheer mystery. I have picked up and attempted to read every auto and farm electrics book with no improvement in the situation. They all seem to start with a chapter entitled "Theory of Electricity". After a few paragraphs I usually close the book and go back to banging out dents. A good friend and I were recently discussing our tractor electrical systems when he stated "I figure it all comes back to applying Ohms Law". At this point ... [Read Article]
Latest Ad: 18-32 Case Cross Motor [More Ads]
