Re: Farmall A low oil pressure when hot
Posted by georgeky on February 25, 2007 at 17:40:28 from (152.163.100.199):
In Reply to: Farmall A low oil pressure when hot posted by dave guest on February 25, 2007 at 16:39:13:
Dave on most old farmalls that is normal. Has yours always done this or is it someting new. I have several old ones and most of them drop oil pressure when hot. I have a C that has done that for more than 30 years and it is still going strong. Try a heavier oil and see if it improves. The bottom of of pump can be tuned a little but you could also ruin it. Bottom cover gasket thickness can also be adjusted ( thicker or thinner) to correct end play in pump gears. If tractors does not knock or peck I dont know if I would be to concerned about it. Especially if oil pressure comes up at high engine speed.
Today's Featured Article - A City Guy's First Tractor - by Fred Hambrecht. After living in apartments in Atlanta for more years than I care to remember, the wife and I decided to move to the country. Humming "Green Acres is the place for me..." we purchased a 29 acre tract about 60 miles south of Atlanta. Next came the house, I could talk about that ordeal for another two weeks... But, I want to talk about my tractor! We didn't even own a lawnmower, and all of a sudden we had enough grass to feed all the starving children of the bovine world. Naturally, I talked ... [Read Article]
Latest Ad: 18-32 Case Cross Motor [More Ads]
