Re: Should not be possible
Posted by dave2 on February 26, 2007 at 15:42:05 from (139.139.35.70):
In Reply to: Re: Should not be possible posted by jdemaris on February 25, 2007 at 11:01:13:
May not be the same situation as yours, but the plugs for my German made model are real expensive and take a long time to work (so I'm told, mine didn't work at all when I got the tractor). The modification consisted of an adapter made from the originals that held a newer plug that gets much hotter. Wiring is direct to each plug from battery power(in my case, I ran a heavy gage wire from each one to a junction block with one wire running to battery power with a push button in between). Takes 5 to 15 seconds (depending on the outside temp) to heat things up. Seems to be easier on the battery too.
Good Luck,
Dave
Today's Featured Article - Third Brush Generators - by Chris Pratt. While I love straightening sheet metal, cleaning, and painting old tractors, I use every excuse to avoid working on the on the electrics. I find the whole process sheer mystery. I have picked up and attempted to read every auto and farm electrics book with no improvement in the situation. They all seem to start with a chapter entitled "Theory of Electricity". After a few paragraphs I usually close the book and go back to banging out dents. A good friend and I were recently discussing our tractor electrical systems when he stated "I figure it all comes back to applying Ohms Law". At this point ... [Read Article]
Latest Ad: 18-32 Case Cross Motor [More Ads]
